Problems with Extrude function
Mr_WTaylor
Message 1 of 18
Mr_WTaylor
I have created my desk top on top of the legs I have created however when I extrude one of the corners has a whole in it. See image. Screenshot 2024-03-05 at 18.17.01.png
How do I prevent this from happening. It's important to sort out today.
Regards
Taylor
Costic Studio
Replies (17)
Message 2 of 18
jhackney1972
Please attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 18
Mr_WTaylor
How dose the export help with this problem.
Message 4 of 18
g-andresen
Then we could see from the extrusion menu whether the circle profile is missing during extrusion.
günther
Message 5 of 18
jhackney1972
Turn this around, if I posted the information you have given the Forum, would you have a clue what I was doing to cause the issue.  I think you will easily see why the Forum can help quicker, and with more accuracy if you had your model to see where things are go wrong.  You also mentioned you were in a hurry.  Providing the model will probably get a much quicker answer instead of the Forum users taking multiple guesses.
Message 6 of 18
Mr_WTaylor
how do I attach the file
Message 7 of 18
jhackney1972
The method is outline in my post, Message #2.
Message 8 of 18
Mr_WTaylor
"Providing the model" how do I do this
Message 9 of 18
jhackney1972
As I posted before in message #2, but I will add it again.  By the way, you must use your Forum post to attach it, not email.
Message 10 of 18
Mr_WTaylor
ive exported it but nothing happened
Message 11 of 18
Mr_WTaylor
It is only giving the option to attach a url, photo or video.
Message 12 of 18
jhackney1972
You use the Attachment Section, at the bottom of a Reply Post, not the icons at the top.
Message 13 of 18
Mr_WTaylor
hope this works.
Message 14 of 18
jhackney1972
For some reason the top of the one table leg is above the sketch profile.  I could not determine exactly why but it is an easy fix as shown in the video.  Model is attached.
Message 15 of 18
Mr_WTaylor
thank you it's fixed
Message 16 of 18
Mr_WTaylor
It's another topic but is it possible to create moving components or do I need to duplicate the file in order to show the component down and up.
Message 17 of 18
davebYYPCU
Joints - only work on components, not bodies.
Down Up, sounds like Slider Joint.
Might help...
Message 18 of 18
Mr_WTaylor
there revolute joints.
