As you can see in the below screenshot, the selection field is cutoff to the point of being useless. In addition feature dialogs are not resizable so this is a problem.
The label for Minimum Face Group Size is also cut off.
Possible Solutions:
- allow dialogs to be resized
- auto size dialogs so that all fields are readable
- reduce the dialog margins (The left margin could be reduced. The right margin should be reduced as it is extremely wide for no reason and is a large part of the "field cutoff" problem.)
