Problem Installing Fusion 360
Message 1 of 10
I recently installed a trial version of Fusion 360. I have been busy with other things and did not use it for the last 2 weeks when I came back to it, it would not load. So I downloaded the trial version again. It loaded but with no top bar giving my name and the time period of the trial. As I wish to gain access to the free start-up, it is very frustrating as to where the top bar has gone. Any suggestions?
Replies (9)
Message 2 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Hmm, that sounds definitely strange. Do you mind posting a screenshot of what you are seeing regarding the top bar? I am curious if it go minimized however. If you look in the top right hand of corner of Fusion (for Windows only I believe), there should be a little arrow where you can collapse the top menus.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 10
Thanks for your reply.
Screen shot attached, the top bar, with name, trial period, help arrow, and
all the icons on the left are just not there.
Message 4 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I found out that this is a known issue that we are looking at. We recently just removed the drop down arrow that I was referring to and as a result, some users are stuck like yourself. Check out my post here that has some more information.
James Youmatz
Message 5 of 10
Hi James.
I tried the solution below and no it did not work, still the same.
I just noticed this option was missing as well. Let's try this - although
it will reset your customizations.
- Open Windows Explorer
- Close Fusion
- Enable hidden folders from Control Panel
- Navigate to C:\Users\\AppData\Roaming\Autodesk\Neutron
Platform\Options\
- Locate NULastDisplayedLayout.xml
- Rename to NULastDisplayedLayout.bak
- Relaunch Fusion 360
Does it appear now?
Message 6 of 10
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
At this time, the only immediate workaround I know of is a clean uninstall and reinstall, although (as mentioned) it seems a bit overkill. If you want to proceed, I suggest making sure all of your data is backed up to A360 first as the clean uninstall utility will wipe all of your offline cache data. Once it is:
  • Restart your computer
  • Download and run our Clean Uninstall utility here
  • Download and install Fusion from this link here
That should restore that file menu. Let me know if that worked.
James Youmatz
Message 7 of 10
Hi James.
I did as you suggested and the problem is still there.
Message 8 of 10
Would I be better off attempting a manual clean rather than an auto clean?
Message 9 of 10
Hi James.
I just downloaded Fusion 360 to my Laptop with the same result. The laptop has never had 360 placed onto it before, this was a brand new installation, which would suggest that the problem is with my account. Very frustrating.
Message 10 of 10
Hi James.
I did a manual uninstall,  reinstalled, and bingo, problem solved.
