Create Slice Plane in Simulation is not work probably.
kuan.khajohn
kuan.khajohn
The slice plane cannot be moved or rotated in Simulation after pressing a scroll wheel -- the middle button on a mouse -- to manipulate an object. When I edit the Slice Planes feature, I can move and rotate but the problem will occur again after operating the scroll wheel. Could you check this issue for me? I think it didn't be like this in the previous update
Thank you,
Kuan
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @kuan.khajohn
Thank you for reporting this issue!
I was able to reproduce that can't edit the slice after rotating with the mouse wheel. Here is my step. http://autode.sk/2wlc9Uv
I reported it to the development team(ARRO-8690), and I will get back to you. Sorry for the inconvenience caused.
***Updated***(14.Sep)
Hi @kuan.khajohn, They have put this issue as a high priority and they are working on it. thank you for your understanding Smiley Embarassed
Many thanks,
Ahreum.
