Possible Bug: Generating STL file
vex
vex
It appears I am now unable to generate an STL file for saving (either by right clicking the body and selecting save stl, or by unchecking send to slicer), but I am able to directly send the mesh data to the slicing software.
There does not appear to be any predefined processes that would trigger this. Geometry is relatively simple with no ill defined features from what I can see.
tallisb
Hello Vex-
Is it possible for you to share your model?
I just tried it with one of mine and it worked just fine.
Also, make sure your model is a valid model and not an "open mesh", such as faces missing, intersecting faces, etc.
Brad
Brad Tallis
Fusion 360 Technical Specialist
vex
Unfortunately I am unable to share that specific model--but it does not appear to be model specific so any other I provide may suffice the same. The most recent report can be found at: CER_217617073
This behavior appears to occur regardless of model and may be an issue with my particular hard/software (dual display, Radeon 7870HD Ghz Edition).
I'm just spitballing at this point: But could it be a problem between Cura 4.5 and Fusion?
JeromeBriot
You could try with my free add-in 3D Print Plus.
