Position of Items Created w/XYZ Ref Planes Locked in Timeline
- Mute
- Permalink
- Report
Sketches and any extrudes of those sketches created using XY YZ ZX planes cannot be dragged and dropped to different positions in the timeline. Noticed the issue started occurring the middle of design session. Issue seems to be machine dependent. Running Win10 latest updates. Works fine on a laptop, but not main desktop. Tried clearing 360 caches, removing C:\Users\<Your-windows-user-name>\AppData\Local\Autodesk\ and re-installing 360. Previously created sketches in the same design are unaffected. Only new sketches and things that reference them seem affected. Created an offset construction plane referenced to ZY plane. The position of the construction plane in the timeline is locked, but any sketches on the offset plane and objects referencing can be moved in the timeline. Norton Quick Scan is clean.
Test case file attached. The Red brick in the time line and its sketch cannot be dragged. The Green Hex and its sketch which was created off of the offset plane can be moved in the timeline.
