Please help: Cannot extrude these 2 screw holes into the model. No target body found to cut.
nmg138
nmg138
Please help. I would like to 3d print this with the holes into the model so I can add in wood screws. I have attached the model file below. Thanks a lot 🙂
g-andresen
The body is a surface body.
However, you need a solid for extruding holes.
Unfortunately, you have deactivated the history so that the construction cannot be reproduced.
günther
nmg138
is it possible to convert a hollow body to a solid one.
nmg138
these are the surface errors that are preventing the extrusion. i guess they need to be stiched or patched.
g-andresen
Here is a rustic form using boundary fill and mirroring of one half.
(view in My Videos)
günther
nmg138
thanks so much andresen :)))))))))
