This just started happening some time in the last few days.
I start a sketch. I create a simple sketch element like a circle. I specify some pre-defined parameter for the diameter of the circle. I press "Enter", and the value for the parameter is converted to a constant. (IE, the link to the parameter is lost.)
If I then go back and edit that value on the sketch, and replace it with the parameter, then it works.
Did I accidentally foul something up in my settings? This is mostly an inconvenience, but also pretty dangerous. I had a CNC run almost get spoiled because a parameter change did not propagate through a model.
Edit: I'm struggling to append my screencast video. The forum software is giving me an HTML error.
Here is a link to the screencast showing this behavior: https://autode.sk/3KEmMct
