After updating to 2.0.12157, I've noticed what I suspect is a bug, but maybe its just a change in behavior. If I'm in a sketch, and go to type in a parameter name for a dimension, hit enter or tab to accept it, the dimension is correct, but it's static, and not actually using the parameter. If I then select the dimension and update it a second time with the parameter name again, it sticks, prefixing the dimension with "fx:".
Certainly seems like changed behavior.
This has been brought up of the Forum a number of times. In one of the linked posts, Autodesk Fusion 360 personnel acknowledge the problem and said a fix is in the works.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
We have addressed this in a new update 2.0.12160.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
