After updating to 2.0.12157, I've noticed what I suspect is a bug, but maybe its just a change in behavior. If I'm in a sketch, and go to type in a parameter name for a dimension, hit enter or tab to accept it, the dimension is correct, but it's static, and not actually using the parameter. If I then select the dimension and update it a second time with the parameter name again, it sticks, prefixing the dimension with "fx:".
Certainly seems like changed behavior.
This has been brought up of the Forum a number of times. In one of the linked posts, Autodesk Fusion 360 personnel acknowledge the problem and said a fix is in the works.
John Hackney, Retired
We have addressed this in a new update 2.0.12160.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
