Odd sketch under constrained BUG.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have the sketch below that uses some projected geometry and should be fully constrained. The odd thing is if I delete the perpendicular constraint it then becomes fully constrained, all the perpendicular constraints were automatically create while drawing. To me it should be under constrained after deleting the perpendicular constraint but I think the 12.00mm and 5.5mm diameter dimensions end up constraining the centre construction line as parallel. I can't easily share the actual design but I've exported the component and Fixed what was the Projected geometry and the export shows the same behaviour.
Edit Testing a bit more I've found if I delete the 5.5mm dimension then add back between the centre line and just the end point of the line it will show fully constrained as well.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
