How to creat equal spacing
dsenanm72
Observer Observer
dsenanm72
Observer
Observer
hell I am learning how to use fusion 360 and I was designing An a 8x10x6 in frame in sketch on top plane . So I was able to do the frame and offset it no problem but when I wanted to insert another 6 x 6 rectangle inside the frame I wanted to space six of them out equally and I tried the rectangle pattern but cannot get equal spacing And I have not been able to find anything on YouTube to help me with what I am trying to learn to design any help would be appreciated thank you I attached a photo below
TrippyLighting
Please share your design. Export it as a .f3d file and attach it to the next post.
g-andresen
Try to recognize how many bars and how much distances between bars and the frame there are. Then multiply the amount of bars by their width. Subtract the result from the total length (inside). Divide this by the amount of spacing.
Result: distance between 2 bars.
The set and calculated values are used to create a rectangular pattern.
günther
artemSIV
