No components available to nest
wesBNQM9
Message 1 of 13
wesBNQM9
Having trouble with nesting. I am working on a new design and to my knowledge, I have designed it just as I always do with each part being its own component. However, when I try to nest, it gives me the error below. Any ideas?
Replies (12)
Message 2 of 13
ryan.bales
Autodesk Support
Autodesk Support
I'm not sure without seeing the design. Are you able to share a link or upload a copy?
Ryan Bales
Fusion 360 Product Support
Message 3 of 13
wesBNQM9
here is a link to the drawing https://a360.co/3CTR3jN i will pm a password
Message 4 of 13
ryan.bales
Autodesk Support
Autodesk Support
Thanks! I'll take a look
Ryan Bales
Message 5 of 13
ryan.bales
Autodesk Support
Autodesk Support
Can you enable downloads?
Ryan Bales
Message 6 of 13
wesBNQM9
Done, https://a360.co/3CTR3jN same password
Message 7 of 13
ryan.bales
Autodesk Support
Autodesk Support
Taking a look now.
Ryan Bales
Message 8 of 13
ryan.bales
Autodesk Support
Autodesk Support
So i cannot do anything with this file. It fails to upload or open in Fusion 360, usually crashing Fusion 360. While i'd love to troubleshoot the nesting issue i'm going to be stuck without it opening. If you could open an older version and export it and PM that i can try again but something is wrong. I'll send the model to the data model team and see if they can figure it out.
Ryan Bales
Message 9 of 13
wesBNQM9
It has a mesh it in which may be the problem.  Let me delete the mesh out and see if that helps
Message 10 of 13
wesBNQM9
just deleted the mesh out to resend and thought I would give it another try. Once the mesh was deleted it would nest fine. Is there a problem with having a large mesh in a file that would keep it from nesting?
Message 11 of 13
ryan.bales
Autodesk Support
Autodesk Support
Very possible. If its part of a component selected for nesting it could be erroring out. I can report this to the team.
Ryan Bales
Message 12 of 13
wesBNQM9
Well, I guess I spoke too soon. Nesting is atleast trying now, but when it nest it is nesting pieces on top of one another. Here is a new link without the mesh. Same password https://a360.co/3IlLPi3
Message 13 of 13
ryan.bales
Autodesk Support
Autodesk Support
Same issue for me, crashes Fusion without CER upon trying to upload.
Ryan Bales
