New to Fusion 360 working with import IGS file
Message 1 of 8
I have a model I uploaded and opened from a igs file. Multiple holes need to be changed and I am unable to use press pull. When I select the wall of a hole it disappears and an arrow with a dimension to somewhere appears. I can only change the chamfer.
Replies (7)
Message 2 of 8
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 community and thank you for posting!
I am sorry to hear that.  May I take a look into this behavior with the igs file on my end?
If it is okay with you, can you please post the file or send it to me (kanehiko.saito@autodesk.com)?
I look forward to hearing from you!
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 8
Do I need to re send the file? I attempted sending it from two computers
and just received a message it could not be posted.
Message 4 of 8
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the update.
I appreciate your attempting to send the file; unfortunately it did not reach to me.
Could you upload the file to your A360 dashboard and share a public link to it with me?
This web page details how to share a design and there is an explanation about sharing on A360 hub in the very lower section of the page.
You would like to post the link in this thread or send it to me via PM.
If you have any questions ,please let me know and I'm happy to help.
Thank you.
Kanehiko SAITO
Message 5 of 8
I have sent an invitation to look at Brian heat engine body
Message 6 of 8
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for inviting me in the project.
I am taking a look into the model and I will get back to you once I have something to share!
Thanks.
Kanehiko SAITO
Message 7 of 8
saito.kh
Autodesk Support
Autodesk Support
Hi @cnc9DGSE,
Thank you again for sharing the file.
I tried to change the diameter of the holes using the press pull command and I was not able to recreate the behavior.
Can you please let me know if I missed something - I would appreciate that you use Screencast to capture how you tried to edit!
Thank you.
Kanehiko SAITO
Message 8 of 8
I am able to do press/pull with my new model. It was a problem with the old model (I think). I re-built the 4 models that need new holes ( in BobCad V28). I don't know what was the problem with the old models, as I could not make any boolean changes in BobCad (the face just collapsed ). Thank you for looking at this for me. I tried the press pull and had no luck. Why it works on your computer is beyond my understanding.
