Need help with patches and stitching
jonavark
Message 1 of 16
jonavark
I am trying to model a guitar neck.
The transitions at the head an heel have been very tough for me.
A while ago I did something to my project and broke the end of the timeline for the neck.
I get a 'modeling error' now at that stitch feature but for the life of me I have no idea what it is.
Also, in this neck model the stitched portions still show seams.  ?
I am wondering if I can upload my project file for some input or should I do this via a support ticket?
It should be a private upload as my client doesn't want the file made public.
Thank you.
Replies (15)
Message 2 of 16
g-andresen
`Hi,
You ask for help in a public forum and at the same time state that you do not want this to be made public.
What are we to make of this?
günther
Message 3 of 16
Warmingup1953
The forum works as a forum as you would imagine...
"Forum....a meeting or medium where ideas and views on a particular issue can be exchanged."
If there is IP you can't share publicly but still need assistance, what often works is if you create a proxy file that reveals your problem or area you need assistance without compromising your desired privacy.
Don't forget to include your Fusion file as well as any screen captures to illustrate the issue. Inserting photos is better than attaching them!
Edit: Apologies for the initial non-inclusive AI generated image!
Message 4 of 16
jonavark
Understood.
Is there any way to drill down into an abstract error message to get hints on what the cause is?
I can't resolve the issue because I have no clue where the error is. Fusion doesn't return much data on errors.
I will try to extract the problem project from the main file and post it here.
Message 5 of 16
jonavark
unnecessary, somewhat arrogant.
I would never have known what a forum is without your help.
Message 6 of 16
g-andresen
That would make sense.
günther
Message 7 of 16
jeff_strater
as discussed, having your design or a cut-down version of it is the best way to get support.  However, you can maybe get some ideas from other Forum users.  This topic has come up quite a lot over the years (I have done some guitar modeling myself, so I pay special attention to that topic).  Those two transitions (neck heel and headstock) seem, for some reason, to be particularly difficult surface modeling challenges.  Everyone who tries to do this seems to encounter issues.  A quick search of the forum returns a fair number of articles.  I just searched for "guitar neck":  https://www.autodesk.com/search?qt=guitar%20neck&sn=en_US&us_op=forums
Jeff Strater
Engineering Director
Message 8 of 16
jonavark
Thank you. Yes. I don't know why it becomes such a problem given all of the amazing designs from Fusion. I had loft transitions that worked but they just weren't right. I followed a few tutorials and it seemed like it was working with spline rails and patches but eventually fell apart. I wish I could get more info from Fusion when errors occur.
I will look at the other posts and will eventually get a file uploaded here. I really appreciate the help.
Message 9 of 16
jonavark
I've uploaded the file .
My main questions are:
On the head transition... did I do that correctly? Should the seams disappear?
I had some trouble with a toolpath for that area so I assumed I had mucked it up somehow.
On the heel transition, same questions. But I think I know where I messed up on the top of the neck, attempting to patch with one patch but the center line points are on the neck and the heel.
I don't want anyone to fix it for me but I would love some insight as to what I've done wrong. I will go look at the other posts here regarding this. I've seen so much of this over the past month I am kind of fried, which is why I had to reach out here.
Thank You to anyone who takes a look.
Message 10 of 16
anneprom_service
Community Visitor
Community Visitor
thanks
Message 11 of 16
davebYYPCU
Without doing it for you, you should consider the end result needing to be smooth(ish) transitions that accord to the design intent.
Most of your problem areas are as sharp corners, and intersecting curves that are not tangent,
Top - two intersections, only one pair are tangent.  Internal curve too many arcs.
Bottom, both radii are not tangent to the straight line.
Panel 1,2,3 should not need intermediate panels here.
This sharp corner (black) point - transitioning a flat plate to the fret point, can do with a curve to smooth it (otherwise a triangle) out.
Patching with tangency, gets a closer result, but the sketches could do with a curved transition. (red curves).
A few clues to work with.
Might help....
Message 12 of 16
jonavark
hmmm
I responded to this last night but I don't see it today.
Image 1:
I tried by best to constrain those two cuves but I am up against the outer profile of the head and I couldn't firugre out how to constrain without distorting those lines.
Image 2:
The extra panels come from the curves for the volute mentioned above. My main question here was whether the transition curves were ok. I don't _think_ those extra panels affected them but I also wish they weren't there.
Image 3:
Again I am constrained but the body design and the neck pocket shape. The changes you suggest would likely undercut the neck at the top of the neck pocket.
Can I ask if seams should disappear after a stitch? I couldn't find out if that was always part of a successful stitch or not.
I am an amateur for sure and I really appreciate you taking the time to look into this.
Thanks!
Message 13 of 16
davebYYPCU
Pic 3, you really going to have a sharp edge on the guitar body - there?
Keep the corner point and maybe change my black curve to a spline for the suggested result.
To a degree the underside of the neck is decorative and slight change not permitted?  You had 2 versions in the sketches.
Display edges or not is a setting - yes a tangent seam will not show, when using Shaded.
Might help….
Message 14 of 16
jonavark
Yes. That is the body edge the neck heel has to conform to. Thanks for the info on the seams.
I have to assume then that the stitching actually failed?
I am a little confused by the result I am getting.
Thank you!
Message 15 of 16
davebYYPCU
There was a stitch error but going back in the timeline fixed it.
Visible Edges / Shaded.
Not sure what parts you're not happy with, given the design restrictions.
Might help...
Message 16 of 16
jonavark
Yes. I did leave that error in the timeline. Apologies. I wasn't using that part of the timeline. My concern is that even after stitching the bodies list still shows 5 bodies. I found this problem while trying to create toolpaths
