Need Help Modifying an STL File Downloaded from Thingiverse: Just Need To Extrude/Extend a Section Of The Model
samirakle
samirakle
Hi everyone,
I'm fairly new to the Fusion 360 and the 3D printing world so please be easy if this is something simple haha. Anyway, I downloaded a laser mount off of Thingiverse for my Ender 3 V2 but the heads on the M3 mounting screws I bought from Home Depot yesterday are too thick for the mount I'm trying to use.
All I'm trying to do here is make the spacing a tad bit thicker so that the other piece of the 3D printed mount can slide onto it without any obstruction from the screw.
I've attached a photo for reference as well as the STL files that need editing. I've gone as far as converting the part that needs modifying into a BRep but can't seem to select and extrude the section that I need. I'm a bit frustrated having spent 1-2 hours on this so far today ahhh.
Thanks in advance!
TheCADWhisperer
I recommend that you remodel it from scratch as a native Fusion file.
This will be a nice easy part that only takes a few minutes.
samirakle
That sounds like a lot of work haha. Is there not an easier way of doing this maybe even outside of Fusion 360?
I can try to remodel it but I'm still very new to Fusion 360 so it'll probably take me many hours. Is there maybe a way I could trace the current STL file to produce sketches from?
Thanks!
