@g-andresen Using my laptop, my software and my design. No errors displayed but missing file browser. This is the same problem we have been dealing with 5+ years now. Autodesk should be a shamed of themselves. The file browser crashes and doesn't come back. And yes, I reinstalled Fusion again and it worked one time and is right back to doing this.
It appears to be when you resize or move the Fusion window on startup or you leave the file browser open when you closed it the last time.
In this state you can open files by going to the menu but forget inserting other designs or using (like in my case last night) the history function.
@MRWakefield nope, nothing. Its moving the window when Fusion is loading or leaving the file browser open that causes the issue. Same problem we have seen over the past 5+ years. I think its the code for that module. It simply does not connect to its peer in AWS. When you call it too early (open in or resize the window) it never connects and thus never renders.
The extra fun part is Fusion resizes itself on startup unless you make it a medium sized window AND remember to close the file browser before you quit
