My client was super impressed when I couldn't open their files...
youcangetme
Message 1 of 9
youcangetme
Client calls, "Hey, got serious problems . Get over here now..."
I get there, open Fusion 360 and try to open their files and...
Please explain to me how I am suppose to load files with Fusion 360 looking like this?
"Oh look, Mr Client! I can't help you. So sorry."
Replies (8)
Message 2 of 9
g-andresen
1. do you receive an error message?
2. are you using an older version as the customer?
3. was the file created by your customer with an “insider version”?
günther
Message 3 of 9
MRWakefield
Perhaps it's a graphics driver issue? You could try the various driver options in the Fusion preferences to see whether that fixes it:
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 4 of 9
youcangetme
@g-andresen Using my laptop, my software and my design. No errors displayed but missing file browser. This is the same problem we have been dealing with 5+ years now. Autodesk should be a shamed of themselves. The file browser crashes and doesn't come back. And yes, I reinstalled Fusion again and it worked one time and is right back to doing this.
It appears to be when you resize or move the Fusion window on startup or you leave the file browser open when you closed it the last time.
In this state you can open files by going to the menu but forget inserting other designs or using (like in my case last night) the history function.
@MRWakefield nope, nothing. Its moving the window when Fusion is loading or leaving the file browser open that causes the issue. Same problem we have seen over the past 5+ years. I think its the code for that module. It simply does not connect to its peer in AWS. When you call it too early (open in or resize the window) it never connects and thus never renders.
The extra fun part is Fusion resizes itself on startup unless you make it a medium sized window AND remember to close the file browser before you quit
Message 5 of 9
MRWakefield
No problem, I thought it was worth mentioning in case it worked for you.
I've never experienced this particular issue with any of my installations (4 individual systems over the past 7 years of using Fusion) and my data panel is permanently open even when closing Fusion, although I am aware (after searching the forum) that others have had similar issues with a blank data panel.
You clearly know more about what's going on at the back end as regards Fusion and AWS communication than I do. I've just performed some tests where I've resized and moved the main Fusion application window while it's loading up and I'm not seeing any issues at all.
Have you tried using Procmon to try and identify where it might be failing?
Marcus Wakefield
Message 6 of 9
bentwookie
I saw Autodesk posted this the other day:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-entire-Data-Pa...
Might be a few things in there to try.
Message 7 of 9
youcangetme
@bentwookie
"The computer is equipped with unsupported or low-performance graphics cards such as Intel HD graphics."
lol
My laptop is an i9 with NVidia RTX 3070. So essentially they don't know what is causing it. To funny.
Message 8 of 9
youcangetme
Here I am trying to send feedback to Autodesk on this issue;
Message 9 of 9
bentwookie
The "causes" part of that article kinda buries the point. What it's trying to describe is the situation where Windows thinks it's doing you a favor by running Fusion (or its subcomponents) on integrated graphics while it lets your 3070 sit idle. For example, while Windows might normally park Fusion on your 3070 when plugged in, it might have decided to use integrated graphics while on battery.
Specifically, they seem to be implying that the process adcefwebrowser.exe might not run well integrated. That said, I couldn't find it in my install to tweak individually. Dunno why.
I'd look for something in your laptop's power management settings to force processes to use your 3070 when on battery.
