- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to turn 3 part of the same base model but with small variations in contour. Each part needs a setup on the main and sub spindle of my machine. I created 6 setups (3 main & 3 Sub spindle)
Each main spindle setup has a Sub Spindle grab operation.
I have 2 issues with these:
1 )in the second and third setup I get a warning:
"Warning: This operation could be invalid in this position. Ensure this is a turning setup, and that the secondary spindle is not clamped"
As everything is the same like the first part I see no reason for this warning. So I posted it as is.
2) When posting (For a Haas DS30-Y NGC), the first sub spindle grab goes perfectly. But the second Sub Spindle grab operation does not post code "G199 R0. (SPINDLE SYNCHRONIZATION ON)." but only "R0. (SPINDLE SYNCHRONIZATION ON)".
So without spindle sync ON I friction welded my part to my Sub Spindle.
Is this a post bug?
Is it linked with the warning?
Any help would be appreciated.
