- Mute
- Permalink
- Report
The attached model is constructed with built-in dimensional tolerances so all the joint locations are between surfaces. Most joint motions function as intended but several are complex enough that a solution remains elusive. (1) When the Lever arm is moved down it correctly pivots connected links to raise the Lifter. However half way through the motion the Connector and Rollers protrude momentarily through the Lifter top surface. (2) The Swivel is designed to be rotated upward 45 degrees by the Push Rod when engaged by Left Link. The challenge is to create a joint that provides this motion and that allows Push Rod to float in the Swivel and Left Link slots. The joint(s) at both the Swivel and Left Link require both sliding and rotation as they rotate and move up and down simultaneously. How can the motions be realistically simulated with the Push Rod?
