Moving a few components slide together
mahdi_razazTJN78
Message 1 of 10
mahdi_razazTJN78
In https://a360.co/428f4BQ I cannot make the components shaft, piston, and gasket slide all together inside the cylinder.
Appreciate it if you could let me know how!
Replies (9)
Message 2 of 10
TheCADWhisperer
@mahdi_razazTJN78
Right click on the Cylinder Component and Pin in place (or Ground).
Message 3 of 10
mahdi_razazTJN78
problem is that the Joint (Slider 11) acts only on the piston, and the shaft and gaskets stay in place. I created the Rigid Group (Rigid Group 9) but it's not working the way I want to.
Message 4 of 10
TheCADWhisperer
@mahdi_razazTJN78
If it were my project, I would use Revolute and Cylindrical Joints (better match to real world DoF).
Message 5 of 10
mahdi_razazTJN78
Regardless of the type of the joint, I need a solution that bundles 3 components together. Changing the joint type is not the solution.
Message 6 of 10
TrippyLighting
It works in the design I downloaded.
I would use the ground-to-parent attribute instead of the pin.
Message 7 of 10
jhackney1972
Downloaded you posted model.  I functions as you specified you wanted it to.  Please clarify your desire.
John Hackney, Retired
Message 8 of 10
mahdi_razazTJN78
If you animate Slider 11 joint, you see that only the piston moves. Shaft and gaskets stay in place.
Message 9 of 10
jhackney1972
You are using the wrong command to animate your Slider 11 joint.  You are using Animate Joint, you should be using Animate Joint Relationships so the your Rigid Group is picked up by the motion.
Message 10 of 10
mahdi_razazTJN78
Perfect! Thank you!
