Move/COPY "create copy" not always always displaying
jasonT2RMQ
jasonT2RMQ
I am trying to use Move/COPY multiple times in a row, and it seems like every time I go there its hit or miss if its going to show the Create copy checkbox  but I do the same process each time.   Any reason for this?  Not sure if its a bug or if there is something that I need to do to make it consistent.
g-andresen
1. please show your process in a screencast.
2. Maybe the  pattern function  is a better tool for you
günther
jasonT2RMQ
As you can see the Create copy option doesn't always show up... quite confusing   Pattern function wont work because the points are random
jeff_strater
it's there.  You just need to scroll down in the dialog (or disconnect the dialog from being docked to the sketch palette) to see it:
Jeff Strater
Engineering Director
