Motion Link is broken [BUG]
Beyondforce
Advisor Advisor
Message 1 of 26
Beyondforce
Hey guys,
It's not new, I thought it was fixed in the last version, but it wasn't!
Sometimes it's working and sometimes not. In general the joints are cranky lately!
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Replies (25)
Message 2 of 26
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Beyondforce,
Hmm, I don't think I'm familiar with this bug. Have you already reported this? I can look into this with our team and see what might be going on.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 26
Beyondforce
Hey @James.Youmatz,
I can't explane it, but this morning I had no issues with the Motion Link. But that's the thing, it's not stable, sometimes it's working and sometimes not. There was an update few hours ago, maybe it triggered something.
Yesterday, I created ML between gear A & B, then tried to create a ML between B & C. Not only it didn't work, but it also broke the ML between A & B. I guess it's my lucky day and I hope it will stay like this, because I have a lot more Joints to create!
Cheers / Ben.
Ben Korez
| YouTube
Message 4 of 26
admaiora
I have the same issue.
Motion link broken
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 5 of 26
admaiora
Someone can show me applyng a Motin Link working?
Admaiora
Message 6 of 26
admaiora
Can someone help me?
I would like to know what's wrong with my workflow, my Fusion or with the tool itself.
It doesn't work for me.
Admaiora
Message 7 of 26
Beyondforce
What happen if you Right click one of the joints and choose Animate model?
Ben Korez
| YouTube
Message 8 of 26
admaiora
This
Admaiora
Message 9 of 26
Beyondforce
Well, it seems like the Motion Link is broken!
What worked for me was, recreating the joints and then recreating the Motion Link. But still, the Motion Link is definitely is broken.
@James.Youmatz, can you help!?
Ben Korez
| YouTube
Message 10 of 26
admaiora
Thank you BK for the help.
Is it possible that nobody noticed this?
I still think that i wrong something or something wrong with my fusion.
Admaiora
Message 11 of 26
Beyondforce
Its not you, its Fusion. There are all kinds of instabilities with the software including the joints solver.
Ben Korez
| YouTube
Message 12 of 26
James.Youmatz
Autodesk Support
Autodesk Support
Hi @admaiora,
Yea, that does seem strange. I'd love to take a deeper peek. Can you share the file with me so I can test and log a bug if there is one? As @Beyondforce mentioned earlier - this is tricky to capture on our end as it isn't very easy to reproduce.
James Youmatz
Message 13 of 26
instructor.stagnaro
Hi @James.Youmatz ,
thanks for the support.
It's not  a singular case, the tool doesn't work at all.
It can be reproduce in anytime in any case, just trying to use the Motion Link and trying to make it work.
Here a video starting from 0.
Attached the file.
Thanks!
Message 14 of 26
admaiora
Sorry. It was me, just auto logged with the Fusion account.
Admaiora
Message 15 of 26
James.Youmatz
Autodesk Support
Autodesk Support
Hi @admaiora,
No worries, figured it was you 🙂
Anyways, got some weeiiirrrd results. It works just fine for me after initial upload...
I'll try creating this from scratch to see if it has something to do with that, but can you please try uploading the file you posted and trying the motion link and seeing if that worked. If it does, then it may be something to do with the capture position - I'd have to check. If it does not, then we know it is something specific to your machine configuration and we would have to dig deeper into this.
James Youmatz
Message 16 of 26
admaiora
hank you @James.Youmatz
yes, the doubt was:
-is it my workflow?
-is it Fusion?
-is it my Fusion in my machine?
What about you @Beyondforce ?
Admaiora
Message 17 of 26
Beyondforce
It is an issue with Fusion. I have experienced it more than one. I remember times when it worked just fine. It started about two updates ago.
Ben Korez
| YouTube
Message 18 of 26
James.Youmatz
Autodesk Support
Autodesk Support
HI guys,
I'll keep experimenting, but I followed @admaiora's video to the T (building it from scratch) and I still could use motion link on my first try. I'm not too sure what might be different in our use cases - I'll examine the video to see if I missed anything. Can you guys please post your machine specs so I can try to nail down if it is specific to something? Peripherals included too please. Something strange is going on and I'm not too sure why I can't reproduce this on my machine at the moment, but I'll keep trying.
James Youmatz
Message 19 of 26
admaiora
[GPU Information]
GPU Device: NVIDIA Quadro 5000
GPU RAM: 2560 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: w\S.ystem32\DriverStore\FileRepository\nv_dispwi.inf_amd64_a655bc7f95e3cd51\nvd3dumx,C:\Windows\System32\DriverStore\Fi:21.21.13.7755
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: On
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Nome SO	Microsoft Windows 10 Enterprise 2016 LTSB
Versione	10.0.14393 build 14393
Descrizione altro SO 	Non disponibile
Produttore SO	Microsoft Corporation
Nome sistema
Produttore sistema	Hewlett-Packard
Modello sistema	HP Z400 Workstation
Tipo sistema	PC basato su x64
SKU sistema	VS933AV
Processore	Intel(R) Xeon(R) CPU           W3530  @ 2.80GHz, 2794 Mhz, 4 core, 4 processori logici
Versione/data BIOS	Hewlett-Packard 786G3 v03.57, 15/07/2013
Versione SMBIOS	2.6
Versione controller integrato	255.255
Modalità BIOS	Legacy
Produttore scheda di base	Hewlett-Packard
Modello scheda di base	Non disponibile
Nome scheda di base	Scheda di base
Ruolo piattaforma	Workstation
Admaiora
Message 20 of 26
admaiora
I have tested the same issue with other pc ( 6 machines).
All with the lastes version of Fusion.
This summer before last updates the files with motion link worked fine.
Now i can open them, they have the motion link, but doesn't work.
Admaiora
