modifying an .stl file
chunk07
chunk07
I have an .stl file I need to modify. I don't have the Fusion file for the model.I need to modify 2 areas to add width. I cannot use scale as there are critical dimensions that would also be effected.
I have successfully converted the model to solid, created offset planes, and split the model at the planes. I can hide the 2 pieces and use extrude to widen the center part as needed.
My question is how do I re-assemble the 3 parts to include the new width?
HughesTooling
Combine?
Mark Hughes
Owner, Hughes Tooling
