Model Render Problem
Whenever I try to render a specific assembly I get the message 'Your rendering could not be rendered because an error occured'.
I am using cloud rendering and am able to render other models (including the two separate components of the model).
[GPU Information]
GPU Device: Radeon RX Vega
GPU RAM: 8192 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: \WINDOWS\System32\DriverStore\FileRepository\c0338885.inf_amd64_648d9ae54bb276d8\B338884\aticfx64.dll,C:\WINDOWS\System32\Dri:25.20.15017.1010
GPU Driver Date: Unknown
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Model ImageModel ImageMessage ReceivedMessage Received
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you share the file with us so we can test it?
Do you have any base features in your design? This forum thread found that finishing the base feature allowed for a completed rendering.
Pawel also suggested a different solution here that you might try.
