Midpoint line
Midpoint line
jeffreyalanbeaudoin
Message 1 of 15
Midpoint line
jeffreyalanbeaudoin
The green midpoint line demonstrated in the videos I've watched is not showing up on lines in my Fusion360. Is there something I am missing?
Replies (14)
Message 2 of 15
jeff_strater
Hi @jeffreyalanbeaudoin,
I'm not exactly sure what you are referring to here.  Can you provide a bit more information?  What command are you using when you expect to see a midpoint line?  The only thing I can think of offhand is that you need to hold down the Shift key during the Dimension and constraint commands.
Jeff
Jeff Strater
Engineering Director
Message 3 of 15
jeffreyalanbeaudoin
Thank you for your response. The videos I have watched have shown a green
point as indicating the midpoint of a line. When I highlight a line in my
software, no green midpoint line appears.
Message 4 of 15
jeff_strater
Below is a video showing the use of the line midpoint during line creation (no action necessary, the triangle will show when you get near the midpoint) and dimensioning/constraining (hold down Shift to show the midpoint triangle for these commands).  Is this what you saw in the training videos?
Jeff
Jeff Strater
Message 5 of 15
jeffreyalanbeaudoin
I don't see a video?
Message 6 of 15
jeff_strater
The video should be embedded right in my post.  What browser are you using?  If all else fails, you can see it here:  http://autode.sk/2zi69C4
Jeff
Jeff Strater
Message 7 of 15
jeffreyalanbeaudoin
I watched the video. Holding shift does not produce a green midpoint line
on my end!
Message 8 of 15
jeff_strater
Can you record a video of what you are seeing?  You can download Screencast here:  https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
The only thing that I can think of offhand is that the lines are not in the sketch you are currently editing.  If you can share the design here, it would help.
Jeff
Jeff Strater
Message 9 of 15
jeffreyalanbeaudoin
Notice the blue highlighted line at the bottom. No green dot midline no
matter what i do...
Message 10 of 15
jeff_strater
@jeffreyalanbeaudoin, did you mean to add a video or screenshot to your last post?  Also, if possible, please share your design here - that will help a lot in figuring this out.
Jeff
Jeff Strater
Message 11 of 15
jeffreyalanbeaudoin
Hi Jeff,
I did add a screen shot, yes. Nobody seems to recieve by screen shots, or
know what "midpoint of a line green dot" I am talking about, which is
amazing because it is referenced often in many of the instructional videos
I have completed.
On another note, is there a proper "order of operations" guide for applying
constraints? I understand what all of them do, but the order of application
tends to be a problem.
Thank you
Message 12 of 15
jeff_strater
Yes, unfortunately, your screen shots do not seem to get added.  What browser are you using to write your posts?  In Chrome, I always just click on the "Photos" icons, select an image, and it is inserted inline in the post.
And yes, I, also, am not sure what "midpoint of a line green dot" you are referring to.  The preview for midpoint of a sketch line is a triangle, with an "X" indicator, which can be blue or green depending on which Environment you have chosen:
Is that what you are referring to?  If you could post a link to the instructional videos you are referencing (and what time in the video), it might help sort this out.
Jeff
Jeff Strater
Message 13 of 15
amitzahirr
Observer
Observer
hi i am havint trouble with this as well. i believe the video the op was referencing is this one. https://help.autodesk.com/view/fusion360/ENU/courses/AP-SKETCH-BASICS
@1:46. I cannot get the midpoint triangle to appear.
Message 14 of 15
TheCADWhisperer
At what time step in the video?
Are you in an active command (like Line or Coincident)?
Message 15 of 15
amitzahirr
Observer
Observer
@ 1:48.
I followed all the instructions to this time. I believe i am using an
active command.
