mesh workspace
mesh workspace
Message 1 of 9
mesh workspace
i can't open mesh work space, i go in preference but i can't apply the changes.
Replies (8)
Message 2 of 9
Phil.E
  1. Open Preferences
  2. Open Preview Features page
  3. Ensure Mesh workspace is enabled.
  4. Restart Fusion
Try again, can you see the mesh workspace?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 3 of 9
i tryed 3 times but still dont work...
Message 4 of 9
Phil.E
First can you verify what build of Fusion you are using? Go to the Help menu, and find the About command.
In the box for About, is your build number 2.0.9305?
Another thing you can try is to open a blank document, then use the small gear icon in the lower right corner to turn off timeline history. The option is "Do not capture design history".
After that, is there a mesh tab on the toolbar? If yes, then turn on timeline history again by right clicking the top node of the model browser and using "Capture design history".
Do you have access to the mesh workspace now?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 5 of 9
the build is the same, I tried following your instructions but still nothing. thanks for support
Message 6 of 9
Phil.E
Sorry this is not working. One more.
Try this,
  1. insert the attached design as a mesh. (does that work?)
  2. Then remove the timeline history. (can you now see the mesh tools tab on the command menu ribbon)
  3. Then put history back into effect.
  4. Can you access the mesh work space - by trying to edit the mesh body?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 7 of 9
now it work, but if i open a new tab mesh workspace is not active
Message 8 of 9
Phil.E
Thanks for confirming that. The issue is logged as a bug report.
Did you try this workaround? (I'm just trying to ensure the most simple workaround is available to you and others)
If you are starting a new design, do these steps help?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 9 of 9
now it worb but i need to follow this step every time
thanks a lot.
