Manufacturing workspace is missing after Fusion update
ian_woodsGSZC7
ian_woodsGSZC7
Updated Fusion and received the following error message on startup -
Could not load the addin in /Users/user name/Library/Application Support/Autodesk/
webdeploy/production/d33deb94f63c0f9e07daa3f1ea6a07e40d8385e/Autodesk
Fusion.app/Contents/Libraries/Applications/CAM360/NaMachineBuilder10.dylib"
The result is that the manufacturing workspace is no longer available in the top left corner workspace dropdown.
Tried to repair, uninstall and reinstall but keep getting the same error message
Using an M1 MAC Air.
Does anyone have any potential fixes for this issue?
dsouzasujay
Hi @ian_woodsGSZC7 ,
could you please follow below article and see the problem solves?
Manufacture Workspace is missing in Fusion
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @ian_woodsGSZC7
When reviewing similar customer cases, we’ve observed that Fusion supports macOS Sonoma 14 and above. Based on this, Im suggesting upgrading your macOS version.
Could you please update to the latest macOS version and check if the issue is resolved?
System requirements for Autodesk Fusion
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
ian_woodsGSZC7
Hi @dsouzasujay,
Thanks for the reply, my IT department managed a manual uninstall and this has fixed the addin error.
Regards
dsouzasujay
Thanks for the update @ian_woodsGSZC7 .
Good to see its working again.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
tobias.eich
Hi, I have the same issue.
My Mac is on Ventura 13.7.8 no update available, I did reinstall Fusion a couple of times and it doesn't work.
The online version works but at my workspace the online connection isn't the best, what can I do?
BR Tobi
