Love the Autodesk Assistant - Share feedback?
bbarney101
Observer Observer
bbarney101
Observer
Observer
Hey.  Assistant has been a great way to automate repetitive tasks.  Is there a place on these forums or elsewhere to discuss and share uses and ideas?  Is there a place to provide feedback and suggestions?
Cheers,
Bruce
dsouzasujay
Hi @bbarney101 ,
You can share your feedback and ideas in the Insider Portal and on forum.
Autodesk Assistant - Fusion Insider
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
DidierRamirezDarjo
Great point, @bbarney101 ; something that would be very useful for the community at this stage is for users to publish their findings, prompt ideas, limitations, and suggestions in the Revit Ideas forum as they discover them, because Autodesk has been quite clear that Autodesk Assistant in Revit 2027 is still in an early Tech Preview stage, so it does not yet behave like a mature, automation-first assistant; at the moment, its strongest value is in specialized queries based on Autodesk’s official documentation, along with contextual help, model queries, and a limited set of model modification tasks, so real-world feedback shared openly by users will probably be one of the best ways to help Autodesk refine it into something more robust over time.
I hope this is useful to you. Regards!
Link Revit Ideas: https://forums.autodesk.com/t5/revit-ideas/idb-p/revit-ideas-en
Didier Raphaël Ramírez Darjo
¿Te resultó útil esta publicación? No dudes en dar Me gusta a esta publicación.
¿Se respondió correctamente tu pregunta? Entonces haz clic en el botón ACEPTAR SOLUCIÓN.
