Not autosaving, also freezing often
subversivespeed
subversivespeed
Fusion 1.27 version
autosave isn't working, also got lots of crashing going on.
Same issue on 3 different machines.
Win11 home 25H2 26200.8037
Unless I want to miss a deadline, I will have to switch over to one of you competitors to finish the project..
3 crashes on the same model in a little over an hour AND losing ALL my work is unacceptable.
TheCADWhisperer
@subversivespeed
How are you loosing work?
Are you not saving your work?
TheCADWhisperer
@subversivespeed
Can you attach a file here that exhibits this behavior (frequently crashing)?
rosie_lucas1
Hi @subversivespeed,
I wanted to check in and see if you saw @TheCADWhisperer follow up questions and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Rosie | Community Manager
