Looking for help making a hole for a hex nut
a_haraldson
Observer Observer
a_haraldson
Observer
Observer
I'm new to Fusion. I have a mounting bracket design with a solid bottom face, to be 3D printed, but I need space for a hex nut to fit in under the existing mounting points. Attached is an angled view of the top of the bracket, the bottom face is flat.
The cylinders' max diameter is the right size to fit the nut. How do I position a hexagonal hole of a certain diameter directly under the mounting holes on the top of the piece?
TheCADWhisperer
@a_haraldson
a_haraldson
Observer
Observer
Thanks for the reply, here's the .f3d
TheCADWhisperer
@a_haraldson
How did you attempt to attach the file?
You cannot use email reply to attach files - you must use the web forum.
You should verify that it is actually attached after replying.
a_haraldson
Observer
Observer
I'm using drag and drop/browse to attach, trying again
edit: that seems to have worked this time. my mistake!
TheCADWhisperer
@a_haraldson
What is the source of the original geometry?
You should observe that there is no solid body in the file - only mesh body.
The mesh body should be converted to a solid body.
You should observe that there are no cylindrical features on the mesh body - only coarsely faceted triangular planar surfaces that sort of look like a cylinder.
Do you have the original file before it was converted to a stl mesh geometry?
Sketch a polygon and dimension so that it is clear what you want...
Are you sure your Units are correct?
I suspect this is 10x larger than what you intended.
