Lofting Over Sharp Radius
Ian.c.Stitt
Message 1 of 10
Ian.c.Stitt
I am trying to create an adapter that goes from a 2 3/16 to 2 1/8 in a 90 degree bend while minimizing the vertical distance it must travel. Basically I want the adapter to start turning direction and "adapting" it's diameter right off of the one plane to the other, but when I try to run a loft it gives me errors and says it is self intersecting. I cannot to save my life get this radius to work. Any help would be appreciated in getting this part to work and I have my sketch geometry attached below. Thank you!
Replies (9)
Message 2 of 10
davebYYPCU
Sweep with Path and Guide rail may be acceptable.
More rails for a Loft if that does not work for you.  (Full solid with Shell)
Might help...
Message 3 of 10
g-andresen
try 2 rails for loft as @davebYYPCU recommended
1. Create  intersection points in the sketch and connect them with a spline or lines/fillets
2. loft with 2 rails
3. Shell from body
(view in My Videos)
günther
Message 4 of 10
Ian.c.Stitt
Wonderful! Thank you guys very much!
Message 5 of 10
TrippyLighting
Following the screenshot in the OP you would not need a loft.
A sketch for a sweep profile and another sketch for a sweep path would be sufficient.
Message 6 of 10
g-andresen
The diameters are (intentionally or not?) not identical.
günther
Message 7 of 10
TrippyLighting
Hmmm..K, 3 sketches and a sweep with guide rail. Sketch 2 isn't really needed.
Message 8 of 10
Ian.c.Stitt
Can I loft along 4 rails to have the sides bellow out a little before sweeping down? And yes the diameters are not identical purposefully; is sketch 2 still not necessary?
Message 9 of 10
davebYYPCU
Yep, be careful what you ask for.  My original Sweep with Guide Rail did not make the bulge, just adjusted the diameters on the way.  The 2 side rails would likely need some tricky construction, unless you describe the limitations to the bulge.
Might help...
Message 10 of 10
Ian.c.Stitt
When I try to do the same intersect and connect with a spline it lets me select the circles to intersect but the purple snap points don't appear. I have tried in the existing sketch, a new one, and a new sketch on a plane parallel with the "bulge" feature. Not sure why I can't just do the same thing as before again just with a different shape of guide rail. Thanks for the help!
