Local Render fails to start after installing May 2023 V.2.0.16265 Update
Pedro_Bidarra
Message 1 of 28
Pedro_Bidarra
I'm not able to start a local renders after today's update.
Tried both on 2 different machines at work with macOS and Windows (paid subscription).
Even the simplest thing like a sphere fails in the default environment with the default steel appearance failsto start the local render (in canvas works).
It was working fine before the update,
In my home machine I've blocked Fusion from updating via the firewall but the Design fails to download because it was already saved with a newer version.
The situation is a bit stressful because I need to have the renders before Friday, June 2.
Edit, June 14: Removed "URGENT" from tile, issue now solved in the latest version.
Replies (27)
Message 21 of 28
pedrobidarra
One week without local renders on Mac. Can you share some timeline or any updates so we can decide on what to do in the mean time?
Message 22 of 28
RajkumarIlanchelian
@pedrobidarra @We have identified the problem and we are testing a fix at this time. We are trying to get this out as soon as possible but it is likely it will be around Monday before we may be able to release an update.
we will certainly keep this post updated.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 23 of 28
pedrobidarra
@RajkumarIlanchelian, thank you for the information, that's very helpful.
Message 24 of 28
Seven-One
Does anyone have any updates? This is so frustrating...
Message 25 of 28
RajkumarIlanchelian
@Seven-One We have identified the problem and we are testing a fix at this time. We are trying to get this out as soon as possible but it is likely it will be around Monday before we may be able to release an update.
Autodesk Fusion
Join Fusion Insider
Message 26 of 28
Seven-One
Thank you !
Message 27 of 28
RajkumarIlanchelian
Please update to 2.0.16486 that is now available. We have addressed this issue in this version.
Autodesk Fusion
Join Fusion Insider
Message 28 of 28
pedrobidarra
Tested on Mac, it's working now, thanks!
