liscene issue
liscene issue
TRD2WIN
Message 1 of 9
liscene issue
TRD2WIN
Hi Team,
Having issuse in my Fusion Personal license, unable to use any of the drawing a custom vertical helix tried all the troubleshooting steps by the Autodesk client support,
Replies (8)
Message 2 of 9
jhackney1972
From your post, it is not really clear what your issue is.  Please clarify and attach your model.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 9
TRD2WIN
Thank you for replying ,
I can not get the attachment section here to do anything,  I have no idea what I am doing wrong
Message 4 of 9
TRD2WIN
i AM TRYING TO CLICK HERE BUT NOTHING HAPPENS
Message 5 of 9
jhackney1972
Select just the word “Browse” and then locate and select your file on your hard drive.  This will attach the model you Exported from Fusion.
Message 6 of 9
TRD2WIN
Thank you that worked
I am having issues trying to attach the guide rails to both ends of the spline when creating a coil, both ends always attach to the same side.
I have tried numerous times and was successful only once. When trying to place the second point at the end of the spline the point that I try to attach to does not seem to exist in space as the cursor does not change when I hover over the end point on the second side.
I am also having a lot of  strange things happening such as trying to delete something and it does not happen....shut the program down and restart it fresh, and it deletes right away.
I am starting to wonder if my laptop is up to the task of handling FUSION
Below is what I copied from the diagnostic screen in fusion
[GPU Information]
GPU Device: Intel(R) UHD Graphics
GPU RAM: 128 MB (Integrated card)
GPU Driver API: DirectX 11.0
GPU Driver Version: 27.20.100.9664
GPU Driver Date: 07/05/2021
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Once again thank you in advance for your time
Message 7 of 9
jhackney1972
First off, this is NOT a License issue.  In the video I point out that I am using a Fusion Personal License.  I made a dimension change in your model just to make it easy for me to do the video, you can change it to anything you desire.  I also changed the type of coil to give you a more definite path edge.  Model I used in the video is attached.
(view in My Videos)
Message 8 of 9
TRD2WIN
Oh my god you made it look so simple  ... thank you so much
I am new to 3d cad I have done a lot of 2d work but this is like I am starting from scratch all over.
I have several other projects that I am working on in Fusion that I am having trouble with that now that I know about this forum I will ask here.
Once again THANK YOU
Tom
Message 9 of 9
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
