Setting Up Contacts in Design Space
vpatilu
Message 1 of 1
vpatilu
Hi to all! I just started Fusion 3 weeks ago and I kind of rushed to simulation. I need to simulate entire assemblies and combination of different assemblies. I tried to do static stress analysis in one assembly and it worked and then with the others. They all worked with some warnings along the way. However, when I combine one assembly to another, I get this error on the pre-check about x numbers of unconstrained bodies/components. I applied automatic contacts but it fixed some but not all. I don't want to manually do the contacts for hundreds of components/bodies. I want to establish the contacts during design time to make sure it will generate errors in the simulation space. The question is, how to do it in the design space? For context, I use the move tool to assemble the components then use the "as built-joint" to generate the joints between components.
Replies (0)
