Launching Fusion 360 produces unknown error: DB error // no more rows available
luisBPX59
luisBPX59
support couldn't help me and told me to post this here. any suggestions?
It's a Windows PC and it has been working before. No idea what changed.
dsouzasujay
Hi @luisBPX59
Please use below article to fix the problem.
Fusion 360 -- DB error
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luisBPX59
Hi @dsouzasujay,
 thank you for your reply. If I download the installer and execute it, there is a popup telling me that the most recent version of Fusion is already installed. I also reinstalled Fusion with this installer. No change.
I don't know any other way to update Fusion without launching Fusion, besides using the latest installer.
L
RajkumarIlanchelian
@luisBPX59 Can you please do the following:
Please close Fusion (maybe need to force quit and make sure there is no process of Fusion 360 in Task Manager) > go to below folder to delete the db file on your Windows OS > Relaunch Fusion again with only one instance.
C:\Users\{YourUername}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{YourUId}\lbr\libraries.db
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
luisBPX59
Great. Thank you. Deleting the db file worked.
