Latest update doesn't work anymore... spinning wheel most of the time!
andrewbarnesHD2ZD
Message 1 of 9
andrewbarnesHD2ZD
Hi just letting you know the latest fusion update sucks!! I usually do design of a city block size and now the wheel just spins when I try to do something in my projects. It's pretty much unusable for me now. I guess I have to move onto another program and I have been using Fusion this way for 5 years with no problem. It's doing the same thing from the latest update on all my computers with fusion installed. I have one i7 and 2 i9's. All 3 with nice video cards. I'm disappointed!
Replies (8)
Message 2 of 9
RajkumarIlanchelian
@andrewbarnesHD2ZD @Are you seeing the performance issue on certain designs or even if you open a new design and start say sketching you are seeing the performance issue?
would be good if you can share your log files from one of the machines. If you help- support and diagnostics- get diagnostic logs is the option to get the log files.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
andrewbarnesHD2ZD
Yes, just on the bigger city block designs. Which is what I normally work on vs small designs.
Message 4 of 9
RajkumarIlanchelian
@andrewbarnesHD2ZD Thank you for sharing the log files.
If this performance impact is to this particular design, would you be able to share this design with our engineering team (We can connect outside of this thread if you cannot share data here) and also will you be willing to invite our engineers to the project? This will help us investigate quickly on what could be happening specific to this design.
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
RajkumarIlanchelian
@andrewbarnesHD2ZD One another thing to check is the logs show that you are on 2.0.15291. There is a newer update 2.0.15293 that we pushed out a couple of days back that addressed a save and performance issue. Can you please update to this build and see if you are having better performance?
If on a restart of Fusion 360, your live update is not working:
1. Go to Help - Support and diagnostics
2. Service utility - IN this run the repair Fusion 360 that will take you to the latest version.
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
en9y37
Hi @andrewbarnesHD2ZD and @RajkumarIlanchelian
I'm passing trough this same performance issues. In order to add further information, I'll say that this same issues happen to me if I work with designs which were started in older versions of Fusion. If I replicate some of this old design from scratch and in a new clear design, everything works fine and properly.
This should be studied, in my case I have a huge library of designs that are meant to be used by inserting into other designs, and this performance issue makes my whole library barely usable.
Message 7 of 9
RajkumarIlanchelian
@en9y37 Is this a design you will be able to share with us or invite us into your project? This will help to understand what could be happening.
Autodesk Fusion
Join Fusion Insider
Message 8 of 9
en9y37
Sure @RajkumarIlanchelian !
I had started this thread before @andrewbarnesHD2ZD started this one.
https://forums.autodesk.com/t5/fusion-360-support/painful-slow-performance-breaking-links-in-linked-...
In my last message you can download two designs to test anything you need.
Message 9 of 9
RajkumarIlanchelian
@en9y37 Thank you. Will connect with out engineering team on this and keep you updated on your original thread.
Autodesk Fusion
Join Fusion Insider
