Double sided joint/movement with parametric input
gvitaleFTG
Observer Observer
gvitaleFTG
Observer
Observer
I feel like this is relatively simple and i'm just missing something.
I want to take 2 components (2 3d boxes touching on one face) and use a parametric input to adjust the degree of the angle between the 2. So if i input "4", it'll set the left block to 2° and the right to -2° (or however the coordinates work out)
I know how to create the parameters, i know how to build the expressions to cut this up correctly. I can even make an as built joint to build this and set limits on the distance one block can travel. But i cant figure out how to get both blocks to mirror eachother essentially. on the same axis.
Any help would be greatly appreciated
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
