joint tolerance
joint tolerance
grazianoZ8TY8
joint tolerance
grazianoZ8TY8
Hi to everyone,
i wanna share with you a problem that i often have while designing complex structures by FUSION 360: it can occur that, adding several joints, between two or more components, one of the joints result in conflict and block an entire part of the structure just because of a misalignment  of 0,00001 mm or less.
Now, my question is: is there the possibility to insert and set a sort of tolerance for the joints. It would be very helpful and i think that the most of us, even if only once, encountered this type of problem.
g-andresen
There is no way to create joints with a defined freedom of movement in one or more axes.
You can define offsets, if that helps.
günther
