Joint to keep two planes aligned
eric202020
Message 1 of 9
eric202020
I need to align the center plane of a beam with another plane (formed by 3 points in a 3D sketch in this example).  A rigid joint doesn't automatically keep the planes aligned if the plane is changed.
I've seen a few similar threads, but haven't found anything like this case.
In the screen cast, I show creating the rigid point and updating the angle to make sure the plane formed by 3 points in a 3D sketch are aligned with the plane through the center of the beam.  If I then move a point in the sketch, I must manually update the angle again.
Is there a way to do this automatically with a different type of joint or some other feature?
Replies (8)
Message 2 of 9
davebYYPCU
No screen cast.
Planes have no geometry so I would say not possible at this stage, because Fusion uses common points in the construction of the Joint, changing the angle of a plane not totally related to the joint has no effect.
Might help....
Message 3 of 9
eric202020
Thanks for the fast reply.  I've added the screencast and made sure to click on "Insert" this time 🙂
The plane is actual a midplane of real geometry, so there should be a solution that I'm just missing.
Message 4 of 9
davebYYPCU
As I said, without the movie,
the moving sketch point has nothing tied to the joint, and nothing to do with the midplane
A line in that sketch instead of the axis, and the joint disc tied to the line, will get it done.
Might help....
Message 5 of 9
eric202020
I removed the axis so it is just a line.  Unfortunately, the joint disc doesn't rotate with the line as it stays true to the coordinates, so the exact same problem.
Message 6 of 9
davebYYPCU
Delete the perpendicular line causing the wrong selection to be made.
You need the joint disc to align on the long line midpoint - for a fighting chance.
The line moves with the moving point, the bar has to maintain alignment.
Might help....
Message 7 of 9
eric202020
OK, adding a new joint origin on the perpendicular line and then selecting the line (where the axis was) as the X-axis of the joint origin fixed works!
I'll do a screen cast for it tomorrow.
Message 8 of 9
davebYYPCU
Yep, nothing to do with either plane.
Message 9 of 9
eric202020
Other than what I'm doing is using the planes to attach a sketch to and doing the lines to attach a joint origin to just so I can place a component.  Joints are very nice in typical cases (bolts, etc) compared with constraints in other CAD systems, but things like this are not very intuitive and seem hacky IMHO.
