Post processor for deckel millplus IT
Hello, I have a deckel maho DMU 50 Evo linear (2011). The controller is  heidenhain millplus ( I believe it's v600) . Does anyone have a working 5 axis post for this machine?
The millplus post from Autodesk is almost correct but the machine can not read the "%programname" at the start or when the code has a "."  After A0 B0 or C0. Ex. A0. B0.
Many thanks for the help!
serge.quiblier
Hello @Anonymous
For the problem with the dot on A0.
You can open the millturn.cps file and alter the following line
var abcFormat = createFormat({decimals:3forceDecimal:truescale:DEG});
in order to change it to
var abcFormat = createFormat({decimals:3forceDecimal:falsescale:DEG});
For the other problem, i don't get it!
At the beginning of the ouput code you should have something like :
%PM1005
What do you want there?
Only %?
Nothing at all, suppressing the whole line?
Can you give more information on this point please?
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
