Joint limits on revolute joints
I seem unable to set limits on a revolute joint which seems to be working otherwise. Three problems:
- Established both components with no angular offset (ie 0º), Yet the joint insists that the normal mode of the joint is at -90º.
- Setting limits provides for a minimum and a maximum. If I set one, it sets the other to the same angle, and the joint will simply not animate, though it does so i the joint editing dialog.
- Can't seem to control the direction of the rotation.
