Joint limits on revolute joints
wilburg
wilburg
I seem unable to set limits on a revolute joint which seems to be working otherwise.  Three problems:
  1. Established both components with no angular offset (ie 0º), Yet the joint insists that the normal mode of the joint is at -90º.
  2. Setting limits provides for a minimum and a maximum.  If I set one, it sets the other to the same angle, and the joint will simply not animate, though it does so i the joint editing dialog.
  3. Can't seem to control the direction of the rotation.
wilburg
People,
I was able to solve all of the problems by putting the joint on the left of the moving component, and then dealing with all positive angles.
I also wish to know if there is any way to set up a joint that toggles its behavior - ie: animate once, the door opens - animate again, the door closes.
