Issues when using "Insert point" while editing T-spline form
FredrikBr
Message 1 of 15
FredrikBr
Hi all,
I updated Fusion 360 yesterday, and now the "Insert point" command no longer seems to work when I edit a T-spline form.
I found a Reddit post which describes the problem well, but didn't find anything about it here in the forums, so I quote:
"With the new update my insert point command seems to be busted. I can’t get lines to project onto the geo unless I place a point on each individual edge. But this is slow and creates bad topology. If I try to project a line over multiple edges all that’s created are the start and end points with no projected line between them. This also creates points all over the form creating unforeseen errors."
(Quoted from https://www.reddit.com/r/Fusion360/comments/xa60pe/issues_with_insert_point_in_sculpt/)
Has anybody else experienced this?
Best regards,
Fredrik
Replies (14)
Message 2 of 15
tomo1230
Hi ! @FredrikBr
Sure. Same for me.
Reproducible.
Although the shape changes?
神原Θ友徳(かんばらΘとものり)Tomonori Kanbara -JAPAN-
この投稿が参考になりましたら、「いいね」を押してください。
この投稿で問題を解決できましたら、「解決策として承認」ボタンを押してください。
Autodesk Fusion 360 Certified User 資格認定
3Dモデリングによる3Dデータの活用法とデジタル・ファブリケーションの実践!
The method of utilizing 3D data by 3D modeling & Practice of digital fabrication!
https://ameblo.jp/tomo1230fly/
(https://linktr.ee/tomo1230)
Message 3 of 15
msilva.robert
Observer
Observer
I'm facing same problem
Message 4 of 15
glenn-chun
Thanks for the bug report and sorry for the inconvenience. We will fix the defect as soon as possible.
Glenn
Glenn Chun
Sr. Principal Engineer
Message 5 of 15
TrippyLighting
@FredrikBr wrote:
... unless I place a point on each individual edge. But this is slow and creates bad topology..
Can you demonstrate why this creates bad topology ?
Message 6 of 15
FredrikBr
The statement about bad topology came from the original Reddit poster and not from me, so I'm afraid I can't elaborate a whole lot on that. If I were to guess, I'd say that in reality the OP is maybe more worried about the quality and smoothness of the resulting surface than about actual bad T-spline topology. My interpretation, I may be wrong.
Speaking for myself, I'm trying to learn the modelling method demonstrated in several YouTube videos by Mr. Giichi Endo. Using the "Insert point" function to create lines across several edges is one of the fundamental techniques employed there.
Best regards,
Fredrik
Message 7 of 15
glenn-chun
The issue has been fixed in version 2.0.14335 which was released a moment ago. Check out What's New. Thank you again for reporting the issue.
Glenn
Glenn Chun
Message 8 of 15
TrippyLighting
Nope! Still does not work!
Not on my dell laptop at work, and not on my MacBook Pro.
Message 9 of 15
glenn-chun
@TrippyLighting Can you create a Plane or Cylinder and try Insert Point Simple?
Regarding the Box case in your video, can you rotate the Box before you hit OK on the Insert Point dialog?
Glenn
Glenn Chun
Message 10 of 15
TrippyLighting
So, my Windows version was on 14335 when I created the screencast in my last post.
Obviously I had to shut it down to start it on my Mac.
My mac was not yet on 14335 so it needed to update.
Once it updated and restarted I performed the same test and it also failed to insert points across one or more bridged edges.
Now that I shut my mac down and restart Fusion 360 on my Windows machine it has to be updated to 14336!
But it still does not work.
When I add a point as shown in the screencast, bridging the center edge while in box view mode it does not insert an edge. However, when I do the same thing in smooth view mode it does insert "something" as I can see the shape changing. But it does not visibly add an edge. Neither in smooth view mode, nor in box view mode.
Regardless whether I rotate the model after selecting the edges but before hitting OK.
Message 11 of 15
TrippyLighting
Plane and Cylinder work!
Message 12 of 15
glenn-chun
@TrippyLighting Version 2.0.14335 went live last evening, and 2.0.14336 went live this morning.
Thank you for verifying that Plane and Cylinder work.
I reproduced the issue with Box in the default isometric view. In that case, two new vertices are created, but edges are not. If you orbit the Box before you hit OK on the Insert Point dialog, you may see new edges created. In other words, new edges may or may not be created, depending on the camera view. Since this can be viewed as flaky behavior, I logged this issue as TSP-4314. Peter, thank you for reporting the issue.
Glenn
Glenn Chun
Message 13 of 15
TrippyLighting
It is more then just "flaky". You are correct that vertices/points are inserted, but only on the selected edges, not in the bridged (but not actively selected ) edges. That means for example they cannot be selected for editing.
Message 14 of 15
glenn-chun
This bug has been fixed with the October 2022 update (V.2.0.14567).
Glenn Chun
Message 15 of 15
FredrikBr
Hi all,
Have not had the opportunity to test this before now, but can confirm that the issue is indeed fixed. Thank you!
Best regards,
Fredrik
