Issue with synchronizing drawings to the designs
wvieveen
wvieveen
Community Visitor
Community Visitor
I'm currently designing a product configurator, but I came across the issue that my drawing does not want to sync to my design. When I try i get an error message. (see attached)
Is this a known concept, and are there solutions for it?
If anyone knows, that would be a great help!
Thanks in advance
dsouzasujay
Hi @wvieveen ,
Thanks for reporting this.
Drawings should normally update and stay in sync with their parent design, so receiving an error during synchronization is not expected behavior.
Since you mentioned this is part of a product configurator setup, there may be an interaction between configurations and drawing references that we need to look at more closely.
I will check with the development team to review this case.
cc: @prakash.kumar32QRY
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @wvieveen ,
If you don't mind can you go to
Help - > Diagnostics & Support -> Diagnostic log files -> This will generate a zip file.
Can you please attach the file here? This will give us some insights into what is happening.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
wvieveen
Community Visitor
Community Visitor
Hello @dsouzasujay,
Attached the zip file.
I hope this helps!
dsouzasujay
Hi @wvieveen ,
can you please follow below article and see if it solves the problem?
"We cannot perform this operation" when opening an assembly or drawing file in Autodesk Fusion
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
rosie_lucas1
Hello @wvieveen,
Did the information provided by @dsouzasujay help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie | Community Manager
