Issue seeing command buttons
Unable to see any of the command buttons. If I scroll mouse over area the info for the button I hover over appears. I have uninstalled and reinstalled multiple times. Trying to learn this software and not impressed so far. Any help would be appreciated. About ready to give up and go back to Solidworks.
dsouzasujay
Hi @Anonymous ,
Try to add Environment Variable.
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @Anonymous ,
The latest Fusion 360 Update has the fix, Build number 2.0.10148.(You may need to restart Fusion 360 to see Auto-Update)
Note: After Fusion 360 updated to build  2.0.10148 version, then you can clear the environment variables.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @Anonymous ,
Can you try updating Fusion 360 to 2.0.10148 - the black toolbar issue should disappear.
Note: You can use the fusion 360 Installer to update fusion 360 to a latest version.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
