someone please explain this. I cannot see any of the buttons in the toolbar.
No idea what to do. Everything works, but I cannot see any of the buttons themselves. Free or otherwise, I am SO frustrated. I've lost 3 hours here. I've uninstalled and reinstalled twice. I have disabled every add-in that might have been the problem. I don't know what else to do.
No idea what to do. Everything works, but I cannot see any of the buttons themselves. Free or otherwise, I am SO frustrated. I've lost 3 hours here.No idea what to do. Everything works, but I cannot see any of the buttons themselves. Free or otherwise, I am SO frustrated. I've lost 3 hours here.
Same issue for me. Before I chose to update it, it was fine but now it's gone completely black. I suspect it's like this for a lot of other users too then
dsouzasujay
Hi @Anonymous,
Please add below environment variable.
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @Anonymous @Anonymous ,
The latest Fusion 360 Update has the fix, Build number 2.0.10148.(You may need to restart Fusion 360 to see Auto-Update)
Note: After Fusion 360 updated to build  2.0.10148 version, you can clear the environment variables.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
