Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Inserted canvas image is skewed
amk741
Message 1 of 18
amk741
This is a dupe of: https://forums.autodesk.com/t5/fusion-design-validate-document/skewed-canvas-insert/td-p/9645613
but that post received no help. It also appears to be a dupe of a 2015 report (see the one comment)
When inserting this image  
 the image gets squished vertically and is no longer the proper aspect ratio
Edit: while the TEMPORARY solution is of course just taking a screenshot of the image and inserting that... I see no reason that Fusion shouldn't fix this issue..
Replies (17)
Message 2 of 18
jordy_keller
The keyword you're looking for is 'calibrate canvas'
Do a search on 'how to calibrate canvas in fusion 360'
When I take picture like this I always include a printed mm reference (taped on the object) for reference.
Message 3 of 18
davebYYPCU
but Calibrate Canvass does not fix, an incorrect Aspect Ratio.
Use the scaling factors in Edit Canvass, to repair it.  (Providing you know the correct sizes)
Might help….
Message 4 of 18
amk741
You can see I have a calibration square already in the image. But if the aspect ratio is off, any amount of calibration won’t solve the skew
Message 5 of 18
Warmingup1953
Try inserting an image that is a screen capture of your file. There may be unusual compression in the original file that Fusion fails to interpret.
Message 6 of 18
TheCADWhisperer
Message 7 of 18
amk741
yeah, thanks.. that definitely works and is what I end up having to do. But I wanted to report this as a bug to be fixed
Message 8 of 18
lcemoore
I too am having this issue.  It started sometime in the last 6 weeks.  After inserted several dozen images over the past 4 years, taking images form multiple sources, I can say this is definitely a new issue.  Inserting a screen shot works for me as well, but given that this is a workaround and the standard method is no longer working as advertised, it should be addressed.
Message 9 of 18
g-andresen
Inspired by an article in the German forum,
I noticed that after right-clicking > Edit and saving (without editing) the canvas in Fusion appears in the correct proportions.
(view in My Videos)
@Phil.E  could this be a hint to the cause?
günther
Message 10 of 18
Phil.E
@Warmingup1953 seems to be onto the same idea.
"Try inserting an image that is a screen capture of your file. There may be unusual compression in the original file that Fusion fails to interpret."
I'll log this with the canvas team. (FUS-198203) Thanks for including example images.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 11 of 18
fellnerseb
Observer
Observer
Is there any update on this Issue? Where can I find the issue tracker?
Message 12 of 18
timbo_1233
Community Visitor
Community Visitor
hey man i figured out a quick solution, for some reason fusion hates the apple deafult aspect ratio, so if you edit your photo on your phone and you crop it to 1/1 aspect ratio fusion will like it again,
Message 13 of 18
Smith.parker.a
Community Visitor
Community Visitor
Just tried this, doesn't seem to fix it
Message 14 of 18
Warmingup1953
Can you share the .png and the Fusion file?
Message 15 of 18
timbo_1233
Community Visitor
Community Visitor
Odd, works just fine for me on my most recent project,##- Please type your
reply above this line -##
Message 16 of 18
BigDogCNC1
Phones insert all kinds of metadata into photos for rotation, cropping, etc, instead of actually editing the pixels in the picture. Rotated pictures when uploading online is a common sign of this. Best thing to do is just open it in paint on your computer and save, it'll write the picture without metadata.
Message 17 of 18
raindog2DX6J
Observer
Observer
I think the point isn't that there is an easy workaround, the point is that every other image rendering software get's it right, but when loading into fusion, it's skewed.
Message 18 of 18
chawl017
Nice to see that almost exactly a year later this is still an issue, nice to see Autodesk really cracking down on these issues quickly.
I guess they were too busy adding the AI assistant no one asked for.
Good work!
