Insert McMaster-Carr does not display everything and it can not be used...
badonj002
Message 1 of 23
badonj002
Insert McMaster-Carr does not display everything and it can not be used 'properly' or find parts to insert step files. I tried clicking on the question mark icon in the top right -> Support and Diagnostics-> Clear Cache Data. It then closed Fusion 360 and restarted and problem persisted.
Issue was first noticed after I opened it today and was notified of recent updates.
I then used my mouse to click and drag it over the window and it selected the text and made it visible so I could navigate allowing me to finally be able to select the Screw I needed and download the STEP file.
To me it looks as if the text is being displayed as 'White', instead of the normal 'Black' causing the text to become invisible against the White background. If I had to guess, it is just a font color setting.
Please review the attached 'fusion360_InsertMMC.pdf' for your review and troubleshooting efforts.
Page (1): The Insert McMaster-Carr window after I opened it.
Page (2): What it looks like when I try to search.
Page (3): What it looks like after I click left mouse button, hold, then drag the pointer from the top left of the window down to the bottom right highlighting the text. (Doing this a few times allows me to eventually get to the McMaster-Carr STEP file I need to insert. You also have to highlight the dropdown menu list to find the STEP file option. )
Page (4): What it looks like on the page details.
Page (5): What download Selection looks like after you highlight the text.
Additional files: 'InsertMcMasterCarrComponent.ai' and 'InsertMcMasterCarrComponent.png'
This is a vector icon I made in the same style as all of your other Insert icons. I use the Insert McMaster-Carr feature quite a bit and if you could use this icon, or one that is easy to quickly identify I would appreciate it. You may have this vector icon for 'FREE', as is, with 'No Strings Attached'. I looked for the font that most closely resembled the large 'M' on the logo. The 'Green" and 'Yellow' colors were obtained from a screenshot of McMaster-Carr's website and selected in Gimp for cose color matching. I designed the icon for a personal project that I am certain will require me to contact your Sales and Marketing once my development is closer to completion. But I do not see any reason why you and other Fusion 360 Users can benefit from its existence if you so desire to use it. You let me use Fusion 360 for free as I qualify for that licence, so as far as I am concerned you already paid me for it. I will sign a release as long as it does not prohibit me from also using it with McMaster-Carr's approval.
Thank you,
Jason
Replies (22)
Message 2 of 23
jacosan7600
Community Visitor
Community Visitor
I experience the same problem, looking forward to a solution
Message 3 of 23
Phil.E
This is most likely a graphics issue.
Can you please check your graphics diagnostic information, under Help?
What kind of graphics card do you have? Are the drivers up to date?
Also, go to Help > About and find the build number you are using. It should be formatted like "2.0.XXXX"
Phil Eichmiller
Software Engineer
Quality Assurance
Message 4 of 23
gery.springer
I have the exact same problem!
Please fix this ASAP!
Message 5 of 23
Phil.E
@gery.springer
Phil Eichmiller
Software Engineer
Quality Assurance
Message 6 of 23
mda
I'm having the same issue but it isn't limited to the McMaster Carr content.  I experience missing text in other boxes in Fusion like the 'share public link' box.  I've performed a system update, updated my GPU drivers and performed a clean uninstall twice to try to sort it.  Of course I restarted my PC at each step as well.  Still not resolved.
Message 7 of 23
Phil.E
@mda
This is most likely a graphics issue. Reinstallation is only helpful when Fusion will not start.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 8 of 23
jhackney1972
Has anyone tried setting their Graphic Driver to a different DirectX in the Preferences panel?  It is a quick thing to check.
John Hackney, Retired
Message 9 of 23
Phil.E
Hi @mda  I see your other post over here:
https://forums.autodesk.com/t5/fusion-360-support/menus-missing-text/m-p/9513730#M88650
Did you try the system variable?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 10 of 23
gery.springer
my graphics diagnostics shows the following:
[GPU Information]
GPU Device: Radeon RX 580 Series
GPU RAM: 8192 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 26.20.15019.19000
GPU Driver Date: 03/02/2020
[Graphics Effects Settings]
Anti Aliasing: Off
Ambient Occlusion: Off
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Simple
Transparency Effect: Better Performance
[Limit effects to optimize performance]
On
I've the latest amd drivers installed.
I've set directx 9 also with NO success!
The tip with the "NEUTRON_WEBBROWSER_ALLOW_GPU_BLACKLIST" system variable worked!!!
Message 11 of 23
gery.springer
THIS WORKED! Thanks!
Message 12 of 23
mda
Got up this morning and applied the 'system variable' solution supplied in my thread and that seems to have sorted it out.  Back to work now.  Thanks for your input.
Message 13 of 23
Phil.E
For the record, and if anyone else finds this post:
If you are seeing white text on a white background, anywhere in Fusion 360, and are on Windows, please create this environment variable. (ht to @lance.carocci )
  1. Right-click on My Computer/This PC on the Desktop or in the Start Menu and select “Properties”
  2. In the left column of the System window that appears, select “Advanced System Settings”
  3. Within the System Properties window that appears, click “Environment Variables” in the bottom right
  4. Within Environment Variables, click “New…” under the System Variables section
  5. For Variable Name, enter NEUTRON_WEBBROWSER_ALLOW_GPU_BLACKLIST
  6. For Variable Value, enter 1
  7. Click OK to save the new variable
  8. Launch Fusion 360
Phil Eichmiller
Software Engineer
Quality Assurance
Message 14 of 23
Had the same issue ,
Fusion on my laptop worked on my desktop would only display white on the catalog. This is a new bug as it worked a few days ago. Used your fix and now everything's fine. Thank you very much.
Message 15 of 23
badonj002
@Phil.E,
Thank you sooo much for this solution.
Message 16 of 23
This just happened recently on my desktop ( May 17). Previously McMaster-Carr catalog worked fine in Fusion 360. Applied the fix and now working. Thanks for solution.
Side note: right clicking on start menu does not display the properties tab, use Control Panel then click System in Comtrol Panel.
Message 17 of 23
My question is.....why is there a GPU blacklist in the first place?
You should be well aware that there are many users out there who use Radeon GPUs and it is these users who appear to be affected.
There should not have to be a workaround for these GPUs the program should work as it did before the update. Who made the decision to include a GPU blacklist and why?
Message 18 of 23
lance.carocci
It's not that kind of blacklist.
The GPU blacklist contains a list of functions to not call for compatibility purposes based on the rendering chipset. Pretty much every app with accelerated graphics has one, somewhere, either for the app itself or one of its third party dependencies (e.g. embedded browser frameworks).
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 19 of 23
JackJohnson321
Hello Phil,
I tried your fix and while it did solve the issue I was having of text not appearing in the McMaster-Carr catalogue, I'm now experiencing issues with my view controls locking at certain moments. For instance, if I'm sketching a rectangle and want to zoom out whilst dragging the sketch, it will not allow me to do so. Also, the orbit and panning controls are exhibiting similar behaviours. This issue arose immediately after making the changes you suggested. Could you shed any light on the problem? Thanks.
Message 20 of 23
Phil.E
What you describe is related to win7-8. Is this your OS? It has nothing to do with video card.
Phil Eichmiller
Software Engineer
Quality Assurance
