importspline is not working with csv file dod you know a solution
jmpframce
Message 1 of 20
jmpframce
i can t import csv file with importspline   , do you know a solution
Accepted solutions (4)
Replies (19)
Message 2 of 20
davebYYPCU
CSV file needs to have 3 values, per line, X, Y and Z.
Might help.
Message 3 of 20
jmpframce
I get xyz
But it doesn't work
I am blocked so solution.i cancel my contract
Message 4 of 20
JeromeBriot
Message 5 of 20
jmpframce
I don't get the script
Message 6 of 20
davebYYPCU
Got this
Message 7 of 20
jmpframce
i don t receive thw scripte
Message 8 of 20
JeromeBriot
Message 10 of 20
jmpframce
what is to import in own script?
Message 11 of 20
jmpframce
i don t knw to import in script   the file
how to do
thanks
Message 12 of 20
jmpframce
i am blocked
Message 13 of 20
HughesTooling
@jmpframce Can you share an example of the csv file you're trying to import? You might need to change the file's extension to txt to be able to attach it to your post.
Mark Hughes
Owner, Hughes Tooling
Message 14 of 20
jmpframce
-21,18 9,81 311,49
4 21,33 324,13
37 29,19 330
71,09 29,19 323,7
99 22,63 308
121 13,71 290,63
136,15 5,91 276,13
Message 15 of 20
jmpframce
not  how to do
Message 16 of 20
HughesTooling
Can you just attach the file as a txt file.?
Looking at what you have posted the format looks all wrong. Some lines have 4 numbers and the comma is missing between others or have you just typed it incorrectly?
Mark Hughes
Message 17 of 20
jmpframce
i have imported file it works
thanks
Message 18 of 20
JeromeBriot
@HughesTooling Because this is not a .CSV file (i.e. Comma-Separated Values) but a .SSV file (i.e. Space-Separated Values). Even better, a .SSVCDS file (i.e. Space-Separated Values with Comma as Decimal Separator).
Message 19 of 20
jmpframce
I have solved import trough the downloading GitHub
One question is the scaling to be in same scale with the drawing
Message 20 of 20
jmpframce
Yes now the import run
The last step is the scaling with the drawing on going
